Weird failure, any ideas?
KirstinS
3,224
899
Brighton
So my commuter with a front BPM hub, 48v controller and battery just cut out on way home Wednesday
Small bump /pothole and stop
But, and this is the odd bit for me, I have power to LED panel and the throttle provides momentary and weak power before cut out.....then nothing
I've checked the battery (fine on my other bikes and reads ok on the meter too)
I've checked the connections. It's a square wave , throttle only, led setup - so simple as they come
Tested all connections, very flummoxed
Controller dead? Seems unlikely to me as no growly, busted fet sounds
Any guesses ?
Or is there , somwhere. A dodgy connection that I have yet to find?
Thanks all
It can be loads of things. Measure the 5v to see if there's a short or your 5v regulator has popped. If that's OK. check the phase connectors aren't melted, then open up the controller to check that tracks haven't melted.
17,317
I could be one or more FETs.
danielrlee
1,401
726
Westbury, Wiltshire
torquetech.co.uk
This sounds like a problem I had a couple of years back with a sensorless controller. All tests proved inconclusive until I tested the controller with a brushless motor tester which revealed a screwed up phase timing. I never discovered the cause, but replacing the controller solved the issue.
My first suspicion though is that you have a dodgy phase connection as d8veh mentioned.
Also, have you tried another known good throttle yet?
KirstinS
3,224
899
Brighton
Ok, I finally gave up and ordered a new controller
Solved ...or so I thought.
Turns out my main Jimmy at insat battery is on the blink. I reckon there must be a loose connection somwhere . It's reading low at output (around 35v) but won't charge
Given the sudden failure over a bump im hopeful for a duff connection over a duff cell/string
Will take it apart tomorrow and have a look see
Gutted though , it's only 16 months old
17,317
bumps can kill the BMS.
Open the battery and check the voltage at the balance leads.
KirstinS
3,224
899
Brighton
Update , after Woosh post i feared theb worst
But then I recalled the intermittent nature of fault
Opened up battery... Two bad welds with flappy nickel strip, see photo
I've lifted for photo but must have been connecting /disconnecting to give intermittent fault
KirstinS
3,224
899
Brighton
So, that was the issue
Dodgy/broken weld on cell pack due to bump
So convinced was I that issue was controller I bought one I don't want ! And an LED
Grrr
But, very grateful a new battery isn't required , everyone needs a spare controller (although I have at least 4 now - but only one 48v)
KirstinS
3,224
899
Brighton
And, for completeness I did test another throttle beforehand and check phases (though not inside controller on.pcb tracks)
I now solder all connections direct including phases since I've had previous issues there
And the thread ends on a happy note
Thanks, as ever , for time and input folks
Reactions: Gaz and harrys
