weld on frame at rear between the chain both sides ?
Oxymoron
29
10
63
Oxford
I have a new 905 torque for a few days and I noticed that there are welds on frame both sides between the chain.
I have looked at a lot of other bikes since then and can't see any that have this weld.
I just keep thinking that it's in a place where a pothole or a hard knock to the frame could cause it to fracture.
can anyone tell me if this is normal?
I don't remember seeing it on the previous 905 which I had swapped out and upgraded to the 2107 version.
craiggor
498
171
Very odd looks like QC found a crack on the frame in the factory and decided to weld it up and ship it out instead of scrapping the frame.
Sent from my MTK8382 using Tapatalk
8,173
David keeps an eye on any Wisper issues/queries so pretty sure he will respond later on.
That's nothing to worry about. There's welds all round the drop-outs, but they don't break.
Reactions: Wisper Bikes
Wisper Bikes
6,211
2,174
68
Sevenoaks Kent
Hi Oxymoron,
On our older bikes the chain stay formed a part of the drop out so any welding was at the very back of the frame. On our more modern (and expensive) frames the whole rear drop-out is moulded, machined and welded into place, that's what you are seeing. This is a much stronger solution and allows us to mould a cavity to take the motor connection to keep it out of harm's way.
If it was only welded at the top I would have been worried.
All the best,
David
