what is it?????
Markxc40
47
11
Just having a re-read of my new ebike paperwork and a tidy up of everything and found this item amongst the paperwork..
I've no idea what it is can anybody explain it please.
36562
Regards
6,319
its a brake pad spacer for when you remove the wheels for transport ect
Reactions: Markxc40
RossG
1,628
1,646
It's one of those things you use to get stones out of horses's hoofs, boy scouts carry them.
Reactions: Markxc40
Markxc40
47
11
Thanks all for your knowledge.
It seems a little complex if it is just to keep the pads apart, is it meant to do other things too?
I'll go and google how to use it.
Best
Andy-Mat
2,214
562
77
Best
It is not complex, it simply prevents the pads on some brake designs from falling out and getting lost in transit.
I asked the same question when I took delivery of my first disk brake e-bike!
Always good to check!
Andy
Reactions: Nealh
6,319
Andy
no its not for that as most calipers have a bolt or clip that holds the pads in place anyway.
it is for when you remove the wheel and put the bike in your car ect so if you knock the brake lever the pads dont get pressed together and thus you need to remove the pads and rest the pistons to get the wheel back on.
Reactions: 01wellsd
Andy-Mat
2,214
562
77
Some pads are not held securely in place, when the disk is not present, and delivery people throw the boxes about, and some brakes a pad can fall out, or maybe even the lever gets operated.
Apparently, the plastic piece prevents pad movement, and my brakes are not even hydraulic.....so its not just for hydraulic brakes as you imply!
That was from my really good friendly LBS here in Germany, after I took it in to show them!
I did not have a clue till then.....
