Wheel sizes
Tazmantic
50
7
52
oxfordshire
Hi there just bought a fat bike, and was wondering is it possible to put different wheels on such as semi fat as obviously the hubs on a fat bike are rather wide.
You can build any rim onto any hub as long as you have the same number of spoke holes in each.
Obviously, you have to make sure that you have enough frame clearance if you go to a larger diameter or wider tyre.
Ok thanks did think that might need to ask, Any ideas how much they would charge?
It depends whether they saw you coming or whether they saw you park your expensive vehicle outside the shop.
