If I've understood the guy from ES correctly, there is indeed a rear coaster brake. The front brake is operated by a remote button that engages the regen on the front wheel and gives moderate braking. However, it's on or off, so not easy to control. I guess it's OK to give drag down steep hills while you do the main braking with the back brake. Doesn't sound like my cup of tea after using Juicy 5 Hydraulics, in fact to me it sounds a bit dodgy for an ebike, but I haven't tried it. Maybe it's adequate after you get used to it
