Which is the best Android app for a sunny ride?
John F
435
55
I want to fix my Android phone to my bars but I fear that most of the map/navigate/etc apps will not be too visible in sunny conditions. Suggestions anyone?
Andy-Mat
2,214
562
77
Make some sort of sun shield, that you can stare down into and put the phone on maximum brightness. Like a square tube, slightly bigger than the screen, and longer, say 10cm long at least, then mock something up with cardboard to see if that helps. If it works, buy some square plastic tubing from a DIY store.....
Plus, listen to the navigational advice aurally, do not rely on the screen 100%.
Andy
John F
435
55
Andy
Yes that sounds like an option. Thinking about it further I was wondering whether an app which had white characters on a black background rather than a white background would at least be more legible, though I haven't found one so far.
2,673
In answer to the title (rather than the OP question): I don't think any app will guarantee you a sunny ride.
Andy-Mat
2,214
562
77
Let us know how you get on please.
Also, the modern "Ear Buds" without cables (BlueTooth) may also be a good option, but only on one side, as you need to hear the traffic still!
Andy
Reactions: richtea99
BazP
358
174
Sheffield
Myself and partner both use different apps when riding and neither of us have difficulty seeing the screen.
Been out in the sun a few times lately and both phones are on the handlebars.
John F
435
55
Yes I've done a couple of sunny rides with my new handlebar mounted phone. Not so much of a problem as I anticipated if you move the bike so it's in the shade. Been looking for apps to use and there are so many it's a difficult choice (which do you use?) Used internet radio and my songs via bluetooth earbuds so far. A map app visble in sunlight would be good though.
8,219
I didn't need an app for todays sunny ride out, instead I poked my head out of the door and hey presto it was already very sunny .
PP100
252
149
To be honest, visibility in bright sun will depend much more on what model of phone you have and the maximum brightness it can manage to compete with full sun (which will vary )
but you could check to see if your phone or Android version has any accessibility settings (eg high contrast ) or even look for a specific app which can override your phone contrast settings temporarily.
BazP
358
174
Sheffield
I have MemoryMap with OS25k maps for the U.K. on which I can draw routes or import gpx files. I also have ViewRanger for when abroad. My partner has used Cyclemeter for a few years but mainly for the after ride stats.
Alyrpal
I use cycle.travel to plan traffic free routes everywhere. It uses traffic data to plan routes. You can see the elevation data and distances, also gives turn by turn by turn data with photos. I export a gpx file into Osmand+ on my phone and that follows the route giving voice turn by turn directions. Only cost is £5.99pa for Osmand. I either mount the phone in a housing on the stem or keep it in a breast pocket.
egroover
976
578
56
UK
Komoot app is great for navigation, set phone to max brightness, and set Komoot to turn off display between turns to save battery. Set your screen timeout to 30secs.
I paid 20 quid for a lifetime sub to all world-wide maps
2,991
My DPC-18 isn't bright enough on the sunniest days. E-paper GPS systems are not at all common, but would be much better for viewing in bright sunlight.
jimriley
561
384
I use Google maps, now has more for cyclists. The black screen/white text could be selected using night mode?
