Wiring QS-S4 Display Throttle
Sean72
Oct 17, 2020
Hello, I've ordered a LH-100 LCD Throttle I received a QS-S4 upon wiring together found one extra wire which is white that LH-100 did not have. Now I have E10 message on the screen? I'm trying to install the QS-S4 on a Boyueda 5400w electric scooter. Any suggestions would be greatly appreciated.
Reactions: Adgoz
3,986
There should be 6 wires: 3 for the throttle, one for the lights, one from the speed sensor and one from the battery to power it and work the battery meter. It's very important that you identify the battery wires on each side of the connector and make sure that they connect only to each other, otherwise you can kill the controller and the throttle, so be careful.
Show us the wires if you need more help.
Reactions: Adgoz
3,986
According to the manual, the wiring colours are the same as any digital control panel:
Red: battery voltage
Blue: switched battery voltage to power the controller
Black ground
Yellow and green: Data Tx and Rx
That leaves the white, which this picture shows as the lights:
If you crossed over the battery wire from the controller onto any of the other wires, or you misconnected the blue one, you might have done some damage to the throttle unit or the controller or both.
Reactions: Adgoz
Sean72
Oct 17, 2020
Upon further checking it's appears QS-S4 is not compatible to the Boyueda scooter. So for the third time I've ordered LH-100 instrument monitor from another site. They say it's matching the description of what I relayed. Only a 3-4 week waiting time. I will update for those who may be interested once delivered and installed.
Reactions: Adgoz
WelshWhoopee
46
Wales
yeah I also have the QS-S4 and it doesn't work for my mercane mx60 and no one in the UK has stock of the LH-100, any has any links and not from china as I know it could take weeks to come to UK
Reactions: Adgoz
Sean72
Oct 17, 2020
Only place I know that supplies LH-100 is China. I looked for one also. China makes them.
Reactions: Adgoz
Adgoz
Jul 10, 2022
Hi sorry to bother you but I broke blue wire can anyone tell me where it should go? Please thank you
8,225
There is no obvious sign on that face to see where it has come from, how about the other side ?
One should with a mag glass see a solder pad with likely two bits of wire ends still attached.
Adgoz
Jul 10, 2022
Same on other side:( can’t find where it was .. anyone can open yours and see ?
