Woosh Rambletta
Jonah
882
246
EX38
The time has come to once again consider the purchase a a couple of folding bikes. Can I just check a couple of things about the 2021 Rambletta.
1. Is it just a front disk brake as in picture? If so, is there a reason for not having a rear disk brake?
2. What motor is used?
3. I think it’s a speed based PAS controller. I much prefer KT current limited PAS settings. Is this configurable?
4. Do you know when the next shipment is due?
TIA
17,316
yes. Most of the braking is at the front, so changing to disc will make the pad replacement interval much longer. I keep the V-brakes at the rear for simplicity. It's easier for us to assemble.
Shengyi DWG07 with freehub body and 8-speed 11T-28T cassette.
No.
The shipment arrives end of March/first week in April but there is a building backlog. If you have reserved, Hatti will give you a build slot/delivery date.
