Worlds first self charging e-bike
danielrlee
1,348
688
Westbury, Wiltshire
torquetech.co.uk
What a load of nonsense. 'Self-charging' ebikes are nothing new (a nonsense concept in itself) and regenerative braking is as old as the electric motor.
Deus
328
143
Dewsbury
Its not regenerative braking though its a hub motor that does the charging so they say
Andy McNish
303
203
Seems all over the place to me.
28kg? Without pannier-rack, lights, mudguards etc?
5kg heavier than the fully loaded Cube Touring bikes (and they are pretty heavy).
OK so how does it recharge?
We know that regenerative breaking isn't worth the weight. Can they use the motor in reverse as a dynamo then?
And the plan is to charge it 'when freewheeling downhill'?
No-one is going to want to pedal that weight uphill or on the flat against dynamo resistance to charge up the battery, so it's a downhill only option. Won't that make it feel, on an MTB trail, that your brakes are permanently on?
Also a 7 speed mountain bike??
And those battery ranges don't look that good - is that meant to be with the battery self-charging function or without?
Reactions: MikelBikel
3,985
You can make any electric bike self-charging. Just put a small direct drive motor in a wheel that doesn't already have one. Connect the three phase wires to a three phase rectifier and add a regulator, or you can use a spare controller that has regen. As soon as you start to move, the DD motor will start charging the battery.
If you add a motor that's bigger than the driving motor, your battery will never run out. Bon voyage!
Another thing you can do is get a a long piece of 6mm threaded bar and mount two 18" propellers from an R/C model shop, one at each end. Install the bar along your bike held on two bearings. A thrust bearing on the front would be best. When you pedal along, the wind will turn the front propeller, which will drive the rear one around and push you along. You don't even need a motor.
If you want to get even more technical, you can use one of these devices to drive your bike. they don't need any charging, nor any battery. you can get the magnets on Ebay very cheap.
Deleted member 25121
Claims to never run out or power and can recharge 70% of the battery if you maintain 10 mph
Self Charge E-bike
It's a crowd funded project, I see they have 1 backer with $10 for the $10,000 enterprise so far with 29 days left. Shipments start in August so they're going to be VERY busy in July!
I also see that one of their 4 man management team is David, the Director of Photography - just what you need in an innovative ebike company eh?
Benjahmin
2,460
1,675
69
West Wales
I find the general lack of knowledge and understanding of basic physics astounding. It's what allows B.S. like this to gain any traction at all.
Maybe schools are still managing to make a fascinating subject as boring as they did in my day, but a life of curiosity and forensic observation can overcome.
Andy McNish
303
203
To be fair, they're not selling a perpetual motion machine, it's just that they are "pedalling" a system that is much inferior to just using the extra weight for a bigger battery or ditching it for a lighter bike. Either would give them better range.
But it's the 28 kg 7 speed 'mountain bike' spec I can't get over :)
And to be fair to Dave the photographer, the mock up looks great. Compared to the designer and engineering team, he's knocked the ball out of the park!
2,652
If the process of turning mechanical energy to electric energy and back was efficient enough it could be worth it. It could flatten out the hills in the sense of requiring the same user input on hill or on the flat; it would just be that the user input required would be much higher on the flat than a cycle without; basically like always going up a not very steep hill. That might be worth it for people who otherwise couldn't make it up the steeper hills.
However, there aren't many people who (a) can't make it up hills but (b) want to ride far enough battery range is an issue and (c) are willing to pay the efficiency and added weight price of treacle on the flat. Maybe not any such people? For others a conventional ebike or conventional bike will be the better answer. Especially given the efficiency is likely to be low and the weight likely to be high.
16,387
I did consider the theoretical possibility of painting the bike in some paint that converts sunlight into electricity.
You park the bike in the sun and gets something like 20W-30W trickle charge 5 hours a day, 100WH-150WH charge, that's enough for commuting purpose.
Andy McNish
303
203
The thing is, this monster weighs 28kg!!
Whatever the added weight of the additional battery charging gear is there are two much better design philosophies.
One is simply use it for more battery.
The other is to reduce weight (the Orbea Gain philosophy) so you need to use less battery assist in the first place.
Now if regenerative breaking gear was very lightweight, cheap and reliable you could just about see it as worth having as an option for when you're freewheeling downhill and would have to brake anyway - free energy is free energy after all. But that scenario isn't actually that common on a lot of rides and the fact that basically no ebike manufacturers have thought this worthwhile suggests that it isn't worth it.
And certainly the enormous weight of this bike suggests this mob haven't cracked it either.
Though we do like Dave's photos!
28Kg isn't an outrageous weight, it's typical of many of the larger ebikes coming out of Germany from R&M for example.
My rides have lots of ups and downs, that's why I bought an ebike, so I'd benefit from being able to recharge the battery on the downhill bits but I suspect the Wh gained might not be that great. The engineering challenge would be how to engage the motor/generator while freewheeling so this would probably preclude using a crank motor.
