Help! Yose power charger
Naycrx
26
Good evening, I have just received my yose power kit, and the charger is a two pin, with also an additional hole in the plug? Does anyone know what kind ofadapter I need to use
Many thanks
wheeliepete
2,047
755
Devon
One of these will do the job, or fit a UK plug, or buy a new lead.
3 pin cloverleaf
kettle
scott gaza
162
24
scone
Hi You could cut the two pin plug off and put a new one on instead, or use an adapter.
Naycrx
26
No worries.... I appreciate any help! Battery now charged,
Next question would be..... The clip on sensor that goes on the crank arm just gets squashed when I put it on? Do I need to order the other type??
scott gaza
162
24
scone
Hi the sensor fits on the frame not the crank arm? i ended up hot gluing mine as couldn't get a nice gap with cable ties alone. I also painted over the magnets as they corrode a fair bit.
