stringsonfire
  1. We went with a Wisper 705, which has been fantastic. I've actually just listed it in the Classifieds as we're moving from Herts to a more foresty area and are planning to get a mid-drive Wisper Wayfarer MTB. https://www.pedelecs.co.uk/forum/classifieds/wipser-705-26-step-through-700wh-only-170-miles-under-warranty.142/
  2. stringsonfire submitted a new listing: [plain]Wisper 705 26" Step-Through 700Wh, ONLY 170 MILES! Under Warranty[/plain] - [plain]Wisper 705 26" Step-Through 700Wh, ONLY 170 MILES! Under Warranty[/plain] Learn more about this listing...
  3. Looking good! https://wisperbikes.com/wisper-works-eroad-bikes-2/
  4. Can they be ordered without quick release? I see the value for track/event bikes, but for a bike you'll lock up outside while you shop/eat/walk etc, it's a security risk/additional expense to remove. The ones on the 705 keep me worried when we park up, and locking up the saddle makes it that little bit more fiddly.
  5. Looks great! Will the low step also come with a more off-road configuration with the larger tyres?
  6. Looks great! Do you know what the weight is going to work out as? What tyres will it take? Loving the 27.5" Plus (2.8" width) on my Merida atm. How will the minimum seat height differ from the 705? My girlfriend's seat is only just above the lowest setting, so hopefully she'll still be able to get on one of these.
  7. I'm struggling to choose a bike rack to hold two eBikes, a Wisper 705 (heavy low-step) and a Merida eOne-Sixty (full suspension with chunky 2.8" tyres). I'm pretty sure it needs to be a tow bar mounted carrier to be able to hold a heavy low step. We're (always) short on space, so a fold-up carrier is a must for us, but less important if you can hang yours on a garage wall. Worth noting that a typical tow bar nose supports 75kg at most, so whatever the specifications for a bike carrier say, it's always 75kg minus the weight of the carrier. Atera Genio Pro Buzz Rack E-Scorpion 2 Thule EasyFold XT2 933/ XT3 934 Best Price £474.95 from RoofBox £309.95 from RoofBox £461.65 / £546.20 from PF Jones Weight of Carrier 19.6 Kg 18.1 Kg 17.9 Kg / 23.1 Kg Remaining Weight Allowance for Bikes 55.4 Kg 56.9 Kg 57.1 Kg / 51.9 Kg Number of Bikes 2 + 1 (Extension Kit 022 781, £70) 2 2 (XT2) or 3 (XT3) Dimensions (Open) (cm) 124 (w) x 65 (d) x 70. 5 (h) 134 (w) x 57 (d) (measured from centre of tow ball) x 70.4-95.7 (h) 123 (w) x 63 x 68 / 123 (w) x 83 x 86 Dimensions (Folded) (cm) 38.5 (w) x 65 (d) x 70. 5 (h) 26.2 (w) 31 (w) x 63 x 68 / 31 (w) x 83 x 86 Bike Ramp Drive-Up Rail 022 782, £47.50 E-Ramp, £34.95 9334, £39.95 Warranty 3 Years 3 Years 2 Years, covers wear and tear 5 Years if you buy direct Tow Ball Clamp Mechanism Press a single lever down once Twist wheel then lever (ratchet?) until secure Press a single lever down once Bike Holder Type Wrap-around straps with sprung streel core Jaw type clamp Jaw type clamp Max Tyre Size 4", may need a set of longer straps? 022 730 up to 3", 022 735 up to 4" 4.7" Other Straps are "quick-release" Unique folding mechanism protects the lights and keeps the dirty bits inside Number plate is easy to remove Adjustable max. height to fit large/tall bikes All Thule products can be purchased with keys matched to your existing Thule gear, see RoofBox All of the above have these features: 13 pin electronics connector Tilt for boot access Locks onto the tow ball with key Bike holders lock onto the bikes with key Integrated light board I'm leaning towards the Buzz Rack new, as it's by far the best value for money, or the EasyFold XT2 used, as it does look slightly easier to fit to the car and it folds up a little neater. The Atera is probably the best feature-wise, as it's got 2 years of development on top of the EasyFold XT (which was released in 2017), but it's currently pre-order for August 2019, and I'm not sure I want to be one of the first people to buy it. Any thoughts on which to go for, or any experience/recommendations having used them?
  8. I think Oxygen are bringing out a larger battery option shortly
  9. OK. Don't suppose you need any consumers to test your pre-production models? Not sure what your requirements are, but we've just backed the eFoldi Lite project on Kickstarter. Between that and an eBike, that's most of my girlfriend's mobility needs sorted (indoors and outdoors).
  10. How will they compare to the 705 and 905? As the hub motor version isn't far away in price. Close to buying a 705 now, but it's hard to spend that money with these new models round the corner
  11. I'll give him a call then. Would feel a bit better about it if I knew more about the motor - can it be replaced if it breaks, how much would it cost, what's the expected life on it, etc
