01wellsd
  1. Brad Bayliss started following 01wellsd
  2. 01wellsd started following Andy-Mat
  3. 01wellsd submitted a new listing: [plain]2020 Wisper 705SE[/plain] - [plain]2020 Wisper 705SE[/plain] Learn more about this listing...
  4. I know that with my wifes Pendleton if the battery rocker switch is off, only the lowest bar shows on the battery. If the rocker switch is on it shows the actual level
  5. I bought one of these last year and can't fault it. I've not had it go vertical on me yet with a hub motor and battery at the rear. I'm keeping my fingers crossed that they still have some of the memory saddles when I get down there!
  6. Could always go through in your Little Tikes car!
  7. I think that what VFR was getting at was that some people only like to charge to 80%, which I believe stops the BMS from balancing the cells.
  8. I'd say at the very least one of those cycling multi tool thingys. I didn't think I'd need tools with a brand new bike. On my first ride to work my saddle came loose where it attaches to the post. Trying to ride whilst also holding the saddle in place with clenched butt cheeks for 7 miles was difficult to say the least!
  9. Forgot to say, This is a review I did on my Wisper 705se if you were to consider them https://www.pedelecs.co.uk/forum/threads/wisper-705se-review.38513/
  10. It was only a joke. It's the Arc Reactor that Tony Stark uses to power his Iron Man armour in the Marvel universe. I think we are many centuries before we see a fusion/nuclear reactor this small! Even though in Back To The Future II there was the Mr Fusion Home Energy Reactor in the future of 2015!
  11. I can recommend Wisper. I use mine for the same sort of thing that you mentioned in your first post. I did have a problem with it, but Wisper collected the bike, fixed it and had it returned within a couple of weeks. Their aftersales is second to none. I've also heard great things about Woosh on this forum.
  12. I've just fitted one of these to my bike, negating the need to charge at all
  13. My 705se is great up hills. I have the version with the torque sensor and handle bar throttle. It carries me (at 13 stone) up Bristol's 13.4% Park Street easily using the throttle and a low gear. I'm not sure on the newer models, but if you put mine in PAS 5 it acts as a cadence sensor anyway. I did a review on it a while back if that helps https://www.pedelecs.co.uk/forum/threads/wisper-705se-review.38513/
  14. I decreased the wheel size on my Wisper's display and increased the top speed of the electric assistance. There is a natural limit on what you will get out of it though, I think the motors are capable of between 18-20mph before they run out of steam!
  15. The guys at Wisper fitted new front forks and it seems to have solved the problem. I haven’t been able to ride too far on it though as I got hit off by a car last week Luckily the bike isn’t too badly damaged, my arm took most of the punishment. At least skin grows back!
  16. Hopefully the last update! The grinding came back after about 100 miles so Wisper have taken the bike back to look at. They have confirmed that the suspension forks are flexing forwards and back, as well as up and down. This is causing irregular pressures on the disc and pads. New forks are on order and I hope to have the bike back soon Thanks again to David and the team for the continuous support and communication throughout.
  17. This is the one that I bought. just had to take the front wheel and handle bars off for it to fit https://www.ebay.co.uk/itm/291743233135
