D2 peddle assist
Hi all I have a d2 the peddles assist is very slow like 5kph is there a way too make it faster Like unlock the peddle assist Or Would it be a faulty sensor Thanks
D2 flashing battery
Hi all my d2 battery light flashes 6 times on the display but the bike seems fine getting speeds up too 28kph any ideas please
Battery Power
Problem solved Thanks everyone for the help I'll do my best too help others
Battery Power
I think I might found the problem, it seems too knock off when the bike is been moved or bumped, I think I have a loose wire in the display when I turn the handle bars it powers off and also its the only connector other then the power supple that if you disconnect and connect back together you need too power the bike back on wish me luck
Battery Power
I feel like I should make a new post it's bad manners hijacking someone else post, So the bike is fully charged 42v and showing full battery on the clock, I double checked all the wiring made sure everything is connected correctly and tight, When I turn on the bike it could knock off in a couple of seconds or stay on for 10 to 15 minutes Any ideas Thanks
Best lock for my ebike
A lock will only keep an honest man from taken your bike you want too slow the person from taking your bike so lock each wheel induvial and then lock the frame, most theft is opportunistic
Battery Power
Thanks for the reply its a new battery I've checked the wiring and all seems fine
Battery Power
Thank you very much It works now however it randomly turns off when I am using the bike, any ideas
Battery Power
The P1 is wrong it's showing P1 is 48 P2 is 200 P3 is 29 When I try change p1 too 36 it won't save Also what are the p2 and p3 ment too be set at Thanks
Can anyone help with a D2 throttle problem?
Your throttle is broken Ignition is just power on and off You have 3 wires that are ment too be connected too a sensor, without that sensor your bike will not drive,
Battery Power
I bought a new battery and when I plug it in too my sons D4s its showing lower power 1 bar of power When I plug it in my d4s it's a full battery Any ideas
Look up my post from about 2 weeks ago I posted the wiring for the D1, D2 and the D3
Where Do You Live V2.0
Dublin Ireland
Battery Power
Did you have any joy on your battery, I have a similar problem on charge all day and only getting 31v
Fiido D3 wiring control box and bike
Back to top
