kiwisibk
  1. Hello everyone, can anyone tell me if I can use the EKD01 display with the TSDZ2 and the Emmebrusa software? Many thanks for any helpful tips!!!
  2. Hello everyone, who can tell me the best possible parameter settings to save as much battery as possible, but still have reasonable motor support? Please be as detailed as possible! Thank you very much!
  3. Hello everyone, if you have a 48V 750W motor, is it possible to limit the power assist mode to 250W? So that you are legally OK in the EU with max. 250W and 25kmh? Many thanks for your feedback!
  4. This is the battery specification: HAILONG-PLUS 48V 12.5AH Specification: (Include 2A Charger) The battery pack fits 48V 250W/350W/500W/750W motor,If your motor power over 750W,we can't provide warranty for this battery Rated capacity: 12.5AH 5P13S Li-ion 2.5Ah 65 pcs 18650 battery cells (china battery cells) HAILONG-PLUS 48V AH Specification: 1. Rated capacity:AH 2. Voltage: 48V 3. Charging Voltage: 54.6V 4. Discharge cutoff voltage: 36.4V 5. Continuous discharge current: 30A 6. Pulse/Max discharge current 50A 7. Max charging current : 5A 8. Charging temperature: 0~45°C 9. Dischargeing temperature: -20~55 °C 10.Operating voltage:36.4V~54.6V 11.Diamesion: 90*109*362mm 12.Weight of battery pack About kg 13.It has no usb power output
  5. Sorry, this is nonsense in my opinion. For the Wh you mentioned there is a separate field in the Parameter Configurator and it is calculated from battery voltage x capacity in Ah:
  6. Hello all, For a 48 V 750 W battery, what value should I enter in "Battery power max (W)" under "Basic settings" when using a 500 W motor? Thanks
  7. The reason I ask is that I have seen that when I turn off the battery switch, the kilometers are not stored correctly in the display. The next time I turn it on there are a few missing... what could this be? I have turned off the odometer compensation because I do not use the data display of the emmebrusa firmware.
  8. Can you please explain this a little better? What do you mean by "battery sw" and "BMS"? Thank you
  9. Can anyone tell me if it is necessary to turn off the Hailong battery with the red power button when the bike is not in use? Or is it enough to turn off the VLCD5 display? Thanks
  10. I have the latest version, so it should be the C2. I am doing well with it!
  11. Why do you need extra sealed bearings? Which ones? Do you have a link? I have only done the thermal conductivity upgrade with silicone pads...
  12. Forget stock firmware and ST Link software, you just need it to test if the USB connection is working properly. You need just the Emmebrusa Java UI tool to set all needed parameters, I flashed it already plenty of times always without any issue. A couple of hints: disable "Street Mode" set at sartup since it restricts the power of you TSDZ2 tremendously. Set "Advanced Torque Sensor" and "Field Wakening". And set the maximum speed in the Java tool, which should not be taken over by the display. Nothing else. I use eMTB assist mode with following values for all four stages: 4 - 8 -12 - 16. Works like a charm with Emmebrusa, you never want to go back to stock software, believe me....
  13. I also had problems with the speedometer not working when I had "odometer compensation" enabled. Try to disable it, then it might work again. In general, I have disabled the data display in VLCD5 and the parameter configuarion as well as it is quite confusing as to what data is displayed. If I disable both, only the battery level is displayed at startup. And I find it much better to configure everything with the Java program on my laptop, because you can always start with the last change by loading it at the beginning (the file with the latest date at the bottom).
  14. Today I made a tour with 25km and about 750 meters of altitude. I have a 12.5Ah 48V Hailong battery. Before the start, the battery was full except for one dash in the VLCD5 display. After arrival just two dashes left. I mostly drove with level two in hybrid mode, which I configured with 150 in power and with 100 in torque assist mode. Since I haven't fitted the engine with the heat conducting pads yet (I'll do it this weekend) it also got pretty warm after all the climbing. What do you guys say about the battery consumption? Reasonable? Or too high? Thanks for your opinions!!!
  15. Wow, thanks for this detailed explanation! So I'll get me something like that https://amzn.eu/d/2gRUsKJ according to these instructions https://github.com/OpenSourceEBike/TSDZ2_wiki/wiki/How-to-improve-motor-heat-dissipation to make a good contact to the housing as the next optimization. Is there somewhere a good tutorial on how to attach the temperature sensor and connect to the emmebrusa software? Thanks
