Woosh starts shipping Tongsheng TSDZ8 with 250W label
whats not to like? Cant find any way to order it on you online shop,and do you ship to Norway?
Best legal conversion kit by far!Expensive
you have completely misunderstood everything,NO your motor is not legal whatever you do with it.
Its a Mac motor.best geared hub motor on the market,1500w peak power,phasrunner controller,cycle analyst and adjustable torque sensor.Not much more need to be said.also overheat protection.do a search on Mac motor, cycle analyst and phaserunner on endless sphere.Its normally a 1000w rated motor
nope,its 250 w they sell both 250w and 500w. in the RTR 250w kit,you get phaserunner controller and 1500w peak power.I should know since i have it. https://www.ebike-solutions.com/en/shop/motoren-und-montagezubehoer/motoren/puma-cst-hinterradmotor-250w.html
Two issues fitting Bafang BBS02B kit, help please.
From Germany
https://www.ebike-solutions.com/en/shop/akkus-und-montagezubehoer/akkuhalterungen/grin-bottle-bob-battery-attachment.html
https://ebikes.ca/shop/electric-bicycle-parts/battery-accessories/double-bob.html
250w Mac motor,phaserunner controller,cycle analyst and adjusable Torque sensor.Peak power 1500w
https://www.ebike-solutions.com/en/shop/electric-bike-conversion-kits/pedelec-conversion-kits/puma-rtr-umbausatz-pedelec-oder-schnelles-e-bike.html
New Conversion
If you want the strongest legal hub motor.look no further.This is a 250w mac motor with phaserunner controller and adjustable torque sensor.Imo the best kit avaliable by far! but expensive https://www.ebike-solutions.com/en/shop/electric-bike-conversion-kits/pedelec-conversion-kits/puma-rtr-umbausatz-pedelec-oder-schnelles-e-bike.html
SWX02 to Q128h
201 rpm 36volt q128H from Bms battery is a good idea.I run mine with 48volt 17ah controller.Very torquy.I had another 36volt q128C 201 rpm with same battery and controller as with the 128H motor, it burned up in a hill the q128H would have no problem with.
Best kit for hilly area for 16 stone and incredibly weak leg muscles
I have the Woosh 48v swx02 250w kit.and I have xiongda.I would recomand the 48 volt 250w swx02 over the Xiongda.It has plenty of torque and a top speed with fully charged battery about 33kmh.(28") wheel.All my 4 xiongda motors are broken. I have changed battery and controller on the swx02 kit,and now use a 48volt 22 a controller.The motor have no problems so far.No overheating tendences
36v to 48v Bafang BBS01 250watt
https://endless-sphere.com/forums/viewtopic.php?f=28&t=94022&start=50
Enerpower 36V 17.6 Ah battery and mounting thoughts
ebikesolution.com sell legal 250 w mac motor kit called Puma .Has to be the best legal hub motor you can get https://www.ebike-solutions.com/en/shop/electric-bike-conversion-kits/pedelec-conversion-kits/ebs-puma-v2-250w-conversion-kit.html
