November 19, 20214 yr The forum is active I have posted questions and got prompt answers that may be worth a try. https://endless-sphere.com/forums/viewtopic.php?f=30&t=98281
November 19, 20214 yr I see the guys at empowered cycles use the KT lcd3 and 4 on their Tsdz's but one has to open the lcd's to individually preprogramme them as well as having to splice the tonsheng displays wiring to the KT displays, one then gets the full extra feature of the display functions like watts drawn, voltage and an extra PAS level. Hopefully the future for these OSF features is to dispense with cable connections and to use a BT capable display which some (I believe)are now compatible and have BT connection to carry out the work.
November 19, 20214 yr I've posted some of the info below in another part of the forum here to gain a wider audience - apologies for (partial) cross posting. I am running the OSF firmware v20.1C.1 (v20.1C.3 is suspended for the time being) I'd promised feedback if anything untoward happened and today it did in that I noticed that although I'd stopped pedalling, the motor was still running on. The 'free running' power seemed to be quite low and with little power - very similar to what you'd get with 'walk mode' I'd guess? Anyway, I stopped the bike (canti -brakes) with little effort, reached down and powered off (down-tube mounted bottle battery) and power back on again and the motor operated normally. Clearly a firmware glitch, but for those who might be spooked by such an event, maybe an ebrake would give some comfort. An ebrake creates a signal for the controller to power down the motor - hopefully the route for that signal is dis-associated from the 'no peddling, switch off the motor' part of the firmware? Just to give an insight into the type of riding I was doing at the time of the 'run-on' issue: > 250w, 36v TSDZ2 running at 25kph pedal assist, VCD6 display, no ebrakes or throttle > battery was maybe 25% discharged > ambient temperature was around 12degC and the motor had not been worked hard (so no heat build-up) and ridden in ECO mode throughout. > bike speed at time of issue was maybe 10-15kph > As I approached a T junction I stopped pedalling and notice the motor noise and looking down to the chain ring, I observed the 'run on'. Anyone else had similar experiences? In addition to the above I have had two ocassions where after stopping for a few minutes and then pedalling off again, the power asssist has not been there. A full stop (no wheel rotation and feet off the pedals) and a power down/back on has resolved the issue. A cycling friend on exactly the same motor but with stock firmware has also experienced this just the once in their 500 miles of use. Apart from that my motor has been fine and has helped me recover from a short illness and I now cycle most places on assist level 1 (ECO) and with peddle assist set to 25kph which is giving me a range between 50 and 60 miles on a 10Ah bottle battery. I have had this exact same thing. it has only happened once and it was about 40 miles into a ride. It’s never happened again despite putting a few miles on the clock. flicking the switch on the battery and back in again sorted it out. I mess with the firmware settings a lot so maybe I can never actually recreate it. But I will keep you all posted
November 19, 20214 yr I have had this exact same thing. it has only happened once and it was about 40 miles into a ride. It’s never happened again despite putting a few miles on the clock. flicking the switch on the battery and back in again sorted it out. I mess with the firmware settings a lot so maybe I can never actually recreate it. But I will keep you all posted This is a really informative thread and a great forum, it's nice to see people helping each other. I'm nowhere near ready to try OSF on my TSDZ2 (I haven't even mounted it to the bike yet ) but I wondered if the STLINK adaptor can be plugged into the lighting part of my Y cable, whilst leaving the speed sensor attached? I'd make a short STLINK adaptor with a male 6-pin Jolet plug, so I can reflash, cycle up the road to test, reflash etc without unplugging anything except the USB cable. Anyone tried it?
November 19, 20214 yr I have had this exact same thing. it has only happened once and it was about 40 miles into a ride. It’s never happened again despite putting a few miles on the clock. flicking the switch on the battery and back in again sorted it out. I mess with the firmware settings a lot so maybe I can never actually recreate it. But I will keep you all posted I've now raised this issue on the Endless Sphere forum here.
November 20, 20214 yr New to this forum. I have a 20 year old trek that has been converted to a TSDZ2, 750W,52V and a 860C display using OSF V20.1C3 . I find it a big improvement over the stock software especially on startups and climbing big hills. To date I have only put 30 miles on it in both road and off-road trails with out any complaints or problems,
November 26, 20214 yr Hi All, great thread this thanks. I installed a TSDZ2 and it seems pretty good. I have just installed the OSF (following the post from Swizz, cheers). Just a note v20.1C has been suspended so I used v20.1B. I have only had a short ride with the OSF (it was raining ...) so its hard to tell what has changed, however the throttle has improved. One thing I was a bit confused about is the controller screen (vlcd5), it hasn't changed, I was hoping to see the battery voltage somewhere. One change is that I can seem to enter the parameter options, EO2, E03 etc however I'm not sure I can change anything. Can anyone see the battery voltage on the vlcd5 after flashing to the OSF?
November 26, 20214 yr For voltage one may have to fit the KT lcd3 and reprogram it as it has the voltage settings, if the vlcd5 doesn't have the settings in the first place it won't be able to display it.
November 27, 20214 yr I've now raised this issue on the Endless Sphere forum here. And there is now a reply from the OSF writer 'mbrusa' on Endless Sphere (link). In short the posts says: ---------------------- Motor spinning without pedaling (phantom pedaling) is a known problem. It is rare and is also present in all previous versions of OSF for stock displays, only those. There was a bug in the communication code with the display, that could have been the cause, but after the modification the problem remained. I have checked many times, for now I have not found anything else. We talk about it here: https://github.com/emmebrusa/TSDZ2-Smar ... /issues/10 --------------- So if the problem is a concern for you, it seems you can either revert back to stock firmware or use a display other than the VLCD5/VLCD6/XH-18 such as the KT-LCD3 or one of the Bafang displays. That will of course involve some jiggery pockery with wires, solder, firmware and so on. Personally I have no interest in the info the bigger displays give and I like the minimalism of the VLCD6 and want the handlebar space for my GPS/Smartphone when needed. More relevant though, is that I've now clocked up 1000Km on the TSDZ2 and the ghost phantom pedalling happened once and wasn't a problem to resolve and gave me no untoward concerns (but each to their own). Edited November 27, 20214 yr by Bikes4two
November 27, 20214 yr Motor spinning without pedaling (phantom pedaling) is a known problem. --------------- More relevant though, is that I've now clocked up 1000Km on the TSDZ2 and the ghost pedalling happened once. Just a clarification. I hadn't heard the term 'phantom pedalling' but it appears to mean the system thinking you are pedalling when you are not. 'Ghost pedalling' is when you turn the cranks without putting in any effort so that a cadence system bike will power the motor and do all the work for you.
November 27, 20214 yr Just a clarification. I hadn't heard the term 'phantom pedalling' but it appears to mean the system thinking you are pedalling when you are not. 'Ghost pedalling' is when you turn the cranks without putting in any effort so that a cadence system bike will power the motor and do all the work for you. You're right - it is important to use the correct terminology - thanks for pointing this out and I've edited my original post. Since that post, further reading suggests (but is refuted by some and is therefore not conclusive) that the phantom pedalling issue may only happen just the once after flashing the OSF, but could re-occur after a fresh OSF flash. I'll be reflashing in a couple of days time - let's see what happens.
November 28, 20214 yr Have any tsdz owners carried out the heat sink mods internally as well as the osf tweaks ?
December 14, 20214 yr One warning when you wire up the programmer the wires to have to be as short as you can make them. I didn't do this and had repeated programming failures until corrected. I have just made my first attempt to communicate with the motor by reading with the following linux command: $ stm8flash -c stlinkv2 -p stm8s105?6 -r TSDZ2_origin.bin I get back error #4. I have searched for the meaning of stm8flash errror codes without any luck. Does anyone know what they are? Secondly, in the quote above you say that the wires to the programmer should be as short as possible. The lead I made is about 130mm from the programmer end to the end of the connector. Is this still too long? Any advice much appreciated.
December 14, 20214 yr Yep, my programming dongle is just about identical to [mention=18152]Swizz[/mention]'s too
December 14, 20214 yr Mine is about 40-50mm longer. I need to eliminate some other potential problems before I get the soldering iron out again.
December 16, 20214 yr 130mm is definitely too long. I made the same mistake and nothing worked until I shortened them to 10-20 mm
July 22, 20223 yr I’ve installed two of these and flashed one of them with osf. (750w 48v 15ah) Used a Mac to flash the OSF but had to instal windows 10 ( it’s free) and an old version of VM ware ( also free.) Made the cables etc. really easy. Have flashed one and kept my partners as stock. We live in the Pennines so local rides are very hilly. Stock they are excellent. I’ve had a 250w Bionx set up and a 350w hub motor kit previously. The TSDZ2 is a world apart. Currently using stock and hybrid assist modes we can climb anything easily. We get a range between 45 and 90 miles depending on terrain and how much shopping I’m carrying. I’ve had a slow learning curve with the OSF settings and I think currently I have the lowest assist setting way to high which is reducing my range. I am also scratching my head a bit with the battery display settings. The voltage displays as 62.5v but it will have dropped a bar on the display. Really impressed with everything about it. Very smooth, powerful, and excellent range. I used PSW power and eBay for the batteries. Fully set up came to £380 per bike. I’d add that the pedals are significantly wider on the cranks ( have a damaged vehicle to show for it ) but this isn’t noticeable when riding. Check your clearances on any bike carrier - I now remove a pedal to carry them.
July 22, 20223 yr Have you tried folding pedals? I use Wellgo F265s - metal mechanism with resin cage
July 23, 20223 yr Have you tried folding pedals? I use Wellgo F265s - metal mechanism with resin cage They are a good option, but we use SPD pedals & shoes - very comfortable, very secure, very very safe. (& serviceable) If you are not used to them note that there are two types of cleat - normal - stiff and firm lock - can be hard to unclip and 'M' Multi release which are fantastically secure and super easy to release. Having gone from having 14 bikes down to six we have a box full of spare SPD pedals! I have seen removable SPDs too but we've still got the box full to get through.
July 23, 20223 yr Topic creep - I thought this thread was about Open Source Firmware? So whilst on that topic, I have been using V20.1c.1 (I have the VLCD6 display) for some time now although I know that there is a v20.1c.2 too - is that the latest release and has 1c.2 been running for a while without issues?
July 23, 20223 yr Topic creep - I thought this thread was about Open Source Firmware? So whilst on that topic, I have been using V20.1c.1 (I have the VLCD6 display) for some time now although I know that there is a v20.1c.2 too - is that the latest release and has 1c.2 been running for a while without issues? I just installed V20.1C.4 about a week ago with good results, from V20.1C.3. There are a lot of bug fixes that were found in versions .2 and .3 and with added assist modes and functions.
July 24, 20223 yr I just installed V20.1C.4 about a week ago Thanks for that. Correct me if I'm wrong but isn't 1c.4 for the 860c display? I'm using the vlcd6 so it looks as though 1c.2 is the latest for the vlcd5, vlcd6, xh18. (BTW, the fixes listed for 1c.4 are very similar to 1c.2 to no doubt to get the firmware for both display sets to a comparable level.) Edited July 24, 20223 yr by Bikes4two
