September 12, 20214 yr Hello I have an city ebike, with Bafang rear hub motor (36V/250W), Silver fish battery (36V/21 Ah). I am forced to replace my controller unit, due to a minor failure (front light stopped working). The current controller unit has this specification: Rated voltage: 36V Maximum current: 17A Rated current: 8A Low voltage protection: 31.5V Throttle adjustment voltage: 1.2v-4.4v (Ex-factory date: 05/2017) Unfortunately, this controller is not available anymore. The question is: may this (current) unit be replaced with the following one: Rated voltage: 36V Maximum current: 12A Rated current: 6A Low voltage protection: 29V Throttle adjustment voltage: 1.2v-4.4v (Ex-factory date: 08/2017) I was wondering if the new unit will work fine on my bike, will not affect the motor/battery? Thanks in advance for any help related to my problem.
September 12, 20214 yr Not enough information. You need to show which control panel you have and all the connectors and wires on you present controller - nicely spread out so that we can see every wire and connector, not in a random birds nest. If it's only the light that's not working, it would be cheaper and easier to install a switch than a new controller. That'll give you the chance to get a better light too.
September 12, 20214 yr Author Not enough information. You need to show which control panel you have and all the connectors and wires on you present controller - nicely spread out so that we can see every wire and connector, not in a random birds nest. Wires/connectors are identical. What differs are the current/voltage values. If it's only the light that's not working, it would be cheaper and easier to install a switch than a new controller. That'll give you the chance to get a better light too. To install a switch? Can you be more specific, please? I am just a bike user, not a technician.
