July 23, 20241 yr Hi, I have a Forme Buxton ProE folding eBike, which has a Bafang H400B Rear Hub Motor, a King Meter E5227 LCD and integrated on/off power switch (wired directly into the back of the display) and a Tianjin Santroll Controller (modelWZKD3615KA-F4, 36v 6A). The King Meter E5227 LCD display has stopped working so I am looking for a replacement display, ideally a basic one that is similar to the existing one. If finding a compatible display alone is not an option, and I need to consider replacing the controller and the display any advice on suitable options would be appreciated.
July 23, 20241 yr Hi, I have a Forme Buxton ProE folding eBike, which has a Bafang H400B Rear Hub Motor, a King Meter E5227 LCD and integrated on/off power switch (wired directly into the back of the display) and a Tianjin Santroll Controller (modelWZKD3615KA-F4, 36v 6A). The King Meter E5227 LCD display has stopped working so I am looking for a replacement display, ideally a basic one that is similar to the existing one. If finding a compatible display alone is not an option, and I need to consider replacing the controller and the display any advice on suitable options would be appreciated. What do you mean by "stopped working"? How did it happen?
July 24, 20241 yr Author A couple of times it took a number of presses of the power button for the display to turn on, then one day is simply stopped coming on at all. Luckily I have two bikes that match, so I have been able to confirm that it is the display that is faulty.
July 24, 20241 yr A couple of times it took a number of presses of the power button for the display to turn on, then one day is simply stopped coming on at all. Luckily I have two bikes that match, so I have been able to confirm that it is the display that is faulty. There are two identical looking versions that have different comms. One uses UART and the other CAN. It's never clear which version people are selling because they're normally sold for a specific bike as a spare part. You can tell which version you have by how many wires are connected to your battery. If it's two wires, you have UART, if it's more, you have CAN. https://www.vrijetijdsshop.be/displays-efiets/20708-display-efiets-taxt-lcd-kingmeter-e5227-vervangt-fs501 It would be cheaper and you'd get a better bike if you swapped out the LCD and controller for KT ones - as long as your battery has only two wires. I think these are the manufacturers: https://topeparts.com/product/e5227-u-lcd-display/
September 8, 20241 yr Author There are two identical looking versions that have different comms. One uses UART and the other CAN. It's never clear which version people are selling because they're normally sold for a specific bike as a spare part. You can tell which version you have by how many wires are connected to your battery. If it's two wires, you have UART, if it's more, you have CAN. https://www.vrijetijdsshop.be/displays-efiets/20708-display-efiets-taxt-lcd-kingmeter-e5227-vervangt-fs501 It would be cheaper and you'd get a better bike if you swapped out the LCD and controller for KT ones - as long as your battery has only two wires. I think these are the manufacturers: https://topeparts.com/product/e5227-u-lcd-display/ Hi, Sorry but I have only just seen your message. That is really helpful, thank you. I will look into both those options and let you know how I get on.
October 11, 20241 yr Author Update on this for anyone with the same issue. The first of the two links is for a Dutch company who don't deliver to the UK, so that options didn't work for me but may work for others. However, the second link is for a company in china who were able to supply a replacement display, programmed to match the one that was faulty. The price was very good, it was shipped very quickly and works perfectly. Thanks Saneagle for the great advice.
October 11, 20241 yr Update on this for anyone with the same issue. The first of the two links is for a Dutch company who don't deliver to the UK, so that options didn't work for me but may work for others. However, the second link is for a company in china who were able to supply a replacement display, programmed to match the one that was faulty. The price was very good, it was shipped very quickly and works perfectly. Thanks Saneagle for the great advice. Thanks for letting us know. We love it when there's a happy ending.
