April 17, 2025Apr 17 I would like to use the same key for my bike and an Abus bike lock - anyone know the best way to get an abus lock manufactured and delivered to UK, given the key code?
April 17, 2025Apr 17 Is this a start the bike key or battery retention lock??? Using the same key for both is the solution, whats the problem or niggle that prompted this train of thought?? Do the two locks even share the same core format ? - A local locksmith should be able to point you in the right direction or rule out feasibility. Assuming keyring mass/clutter is a driving force here, personally if the battery retention lock i would simply keep the battery key with the charger (no longer on the keyring), and if the bike start up key, simply replace the key start with a non key option, (magnet + hydraulic brake sensor, or perhaps a rfid tag for starters). but i am cheap
April 17, 2025Apr 17 Author No. The Bosch motor has an Abus key, and Abus can provide their locks manufactured for your (registered) key code. I just have not been able so far to find a supplier in UK who will get this done for me, and Abus does not deal directly with customers.
April 17, 2025Apr 17 Have you tried a locksmith? one should definitely have trade connections to Abus or know how to establish them.
April 17, 2025Apr 17 Author No I have not. I am looking to buy an Abus lock, manufactured to match my existing Abus key (for the Bosch motor), not to get a key. This is something they offer - takes about a week I understand - but I need a supplier to organize it. I suppose a locksmith might have the connections. I might try that if simpler solutions do not turn up, or simply give up. It would be convenient, but not that important.
April 17, 2025Apr 17 Armed with info from 20yr old village pub lockin conversations with a locksmith, and viewing a few lockpicking you tubes as my sources.. If the keys are the same shape/size then the lock cores should be the same dimension too. a new core for your lock matching the same codes as your bike may need a locksmiths professional credentials to buy Bosch may have negotiated a walk around as an option to its registered resellers?? Check you tube for your abus lock and picking / core removal vids.. an example of a padlock/core
April 17, 2025Apr 17 Author Thanks for all the answers folks. I have found www.ebike24.com can supply them to UK, though it says to expect 4 weeks delivery and the Bordo 6500KA I was looking at is around £50 dearer than the cheapest (same day delivery) local purchase (without key matching).
June 30, 2025Jun 30 Thanks for all the answers folks. I have found www.ebike24.com can supply them to UK, though it says to expect 4 weeks delivery and the Bordo 6500KA I was looking at is around £50 dearer than the cheapest (same day delivery) local purchase (without key matching). Yes, I have used ebike24.com here in Germany for Abus one key locks, they are one of the few that offer the service and Abus don't do retail. They have the Bordo 6500KA with one key at 230.95 Euro (nearly 200 quid) which is also about 50 Euro more than the standard and also quote 3-4 weeks delivery, don't know if that's cheaper than the UK be interesting to know. They also charge around 6 Euro shipping here!
