May 13, 20251 yr Fabulous bike but the thumb throttle has stopped working hardly use it.Any ideas to solve the problem? Thanks
May 13, 20251 yr Fabulous bike but the thumb throttle has stopped working hardly use it.Any ideas to solve the problem? Thanks Was it working, then it just stopped on its own, or did you do something that caused it to stop working, like fiddle with the LCD settings, ride in the rain, drop the bike, wash the bike, or what?
May 13, 20251 yr Author Check the throttle on off switch first. Where is that please?Don't get me wrong the bike is a pleasure to ride
May 13, 20251 yr Where is that please?Don't get me wrong the bike is a pleasure to ride Can you see the square button below the throttle lever? Push once. It's on when it's depressed.
May 14, 20251 yr Check the throttle connection for loose wires and inspect for damage. A controller reset or throttle replacement might help. Good luck!
May 14, 20251 yr It works perfectly now!Thanks again I didn't notice the message right away. Glad you managed to solve the problem!
