Speical Offer on Tongsheng 85TS kit with 36V 15AH 540WH bag battery £349 complete
Thank you you asked that question. Yes, it's for 135mm dropout. I will put that info on the web page.
Because trains have started banning conversions, I'm on the lookout for an inexpensive lightweight pre-built folder with:
  • Decent range
  • Easy to replace discrete battery
  • Easily accessible EAPC markings (speed limit, manufacturer details, 250W etc.)
  • Hi-viz frame colour
  • Front and rear cameras
  • Reverse parking camera
  • Self-balancing roll alongside when walking function
  • Drone
  • Disc brakes (one on the front minimum)
  • Tyres at least 1.75" wide
  • Effective mudguards with mudflaps
  • Preferably with front suspension
  • Conquers hills with ease
  • Dual chainring for extreme hills, heavy trailer towing, extreme weight gain
  • Pannier rack
  • Loud horn
  • Compass on handlebar
  • Folding pedals
  • Handlebar which swivels to the side or folds down for hallways
  • Thru rear axle for heavy trailer towing
  • Mounting point for front basket
  • Fully customisable controller firmware
  • Handbar mirrors which show more than my shoulders or elbows
  • Bright headlight
  • Large sensibly separated bright indicators fore and aft
  • Independently powered battery overheat alarm
  • 6A phone charging port
  • Dual D-lock friendly
  • 20A 12V power outlet for heated clothing or electric blanket for camping
  • Heated handlebar
  • Immobiliser
  • 240V inverter
  • Alarm
  • GPS tracking
  • Automated crash detected emergency services call function
  • Convenient to pick up and carry
  • Easy to roll when folded
  • Handlebar activated tyre shredding tack deployment system for pursuers and neighbours
  • Optional folding roofed fairing with windscreen wiper(s)
  • Remote activated immobiliser
  • Small beer fridge
  • Very small microwave oven
  • Integral fold or roll-out solar panel array for off-grid charging
  • Ultrasound or X-ray rider buttock recognition immobiliser system
  • Remote activated saddle taser
  • Etc.
Not an exhaustive list by any means, just covering the basics. Do you have any plans to sell such pre-built folders "Woosh" branded with this or some other kit?
Edited by guerney
  • Replies 50
  • Views 4.9k
Because trains have started banning conversions, I'm on the lookout for an inexpensive lightweight pre-built folder with decent range, disc brakes (one on the front minimum), tyres at least 1.75" wide, effective mudguards, preferably with front suspension, conquers hills with ease, pannier rack, mounting point for front basket, bright headlight and indicators, 2A phone charging port, power outlet for heated clothing, immobiliser, alarm, GPS tracking, remote activated immobiliser and saddle taser, convenient to pick up and carry, easy to roll when folded, optional folding fairing with windscreen wiper etc. Do you have any plans to sell such pre-built folders "Woosh" branded with this or some other kit?
The Woosh Faro (https://wooshbikes.co.uk/?faro) may be worth a look but you could save money by converting a second hand carbon frame bike with this Tongsheng 85TS kit.
Train conversion bans may become more popular, has to be pre-built.
I was thinking of creating a new range with the tongsheng 85TS kit but finding myself too old now. I leave the decision to Andy.
It may be easy to remove the battery and put it in a regular backpack or bag.
That won't stop the bike being a conversion, but may stop guards noticing it's an ebike at all.
If you retire you die. Happens every time. The train-friendly folder I've briefly described above would be a popular recipe to get right, even without the remote activated saddle taser, or ultrasound or X-ray rider buttock recognition immobiliser system.
Edited by guerney
The bag battery has Anderson connector, very easy to connect and disconnect. You can put it in another bag anywhere on the bike like inside a side bag for the luggage rack.
The dimensions of the battery are 22cm L x 7cm W x 8cm H. Weight: 2.3kgs.
Edited by Woosh
Because trains have started banning conversions, I'm on the lookout for an inexpensive lightweight pre-built folder with decent range, disc brakes (one on the front minimum), tyres at least 1.75" wide, effective mudguards, preferably with front suspension, conquers hills with ease, pannier rack, convenient to pick up and carry, easy to roll when folded etc. Do you have any plans to sell such pre-built folders "Woosh" branded with this or some other kit?
https://uk.dyucycle.com/products/dyu-t1-pedal-assist-torque-sensor-electric-bike?
Thanks, discrete battery is a definite plus (added to my list above). However, would it be a bumpy ride without normal spokes, rough on the wrists without front suspension? Without 26 beeellion pounds to fix them all, the pothole situation will only get worse. Also, I've noticed a lot of Chinese manufacturers don't mark their bikes with manufacturer details, 25kph, 250W etc. in easily accessible places.
Edited by guerney
Could hide the conversion - I've at least two folding bike bags, save train guards throwing me off.
Is the torq sensitivity adjustable, and is there any chance you'll have a 20" version one day?
The torque sensitity is set in the firmware. You have the usual 5 levels of torque from the + and - buttons.
Sure.
I've got mine now. I have to wait for a bike to install it in. I had a plan for it, but I forgot that the motor has the torque sensor in it. I thought it was separate. My plan was to use the motor in one bike and the battery and controller in another with small wheels, but that's not possible.
Woosh, can you remind me how the torque sensor works? Is the motor sensorless, so the small pins are used for the torque signal?
I will open the motorto take some pictures.
As I understand from member mechaniker, there is a microcontroller inside the motor that multiplexes the PAS, torque and Hall outputs to send back to the controller using the old 3 Hall wires.
*Hall wires, not phase wires.
Edited by Woosh
What a great product you have there - you'll certainly be giving the likes of Cytronex and BoostBike a run for their money. Those two products do have smartphone 'apps' though - I don't suppose the 85TS product has such a thing in it's development line does it? An app of course is just icing on the cake and by no means an essential.
Might there be a 700c wheel version coming along anytime soon?
You've clarified the OLN as 135mm but what about dropout size - does the motor fit in 9mm drop-outs or will 'fettling be required' to get the dropouts to 10mm?
Ah, I wondered how that was done - very clever.
Now we need some user feedback, especially how the torque sensor affects the ride experience versus something like the KT current control method.
Tempting ! 12 kg full suss NRS1 £195 + add the Woosh 4.5 kg kit .
[ATTACH=full]64907[/ATTACH]
Top spec full suspension bike with torque sensor and decent size battery 16.5kg £550 !
https://www.facebook.com/share/1BbeJD7RE6/
This is only "8kg". Range will be bloody decent with 15Ah. No mudguards tho. 12.5kg converted, without mudguards. Linking by way of illustration only - rear dropouts are probably not wide enough for the motor, but such a lightweight long range conversion or converted product, with some other similar frame and fork of the same weight, would make for a desirable cummuter. Train-assist commute compatable, if Woosh pre-built and branded. Other light 20" wheeled folding commuters max out at 10Ah, if that. Usually 5Ah to 7Ah, or less.
https://www.ebay.co.uk/itm/358000220633
Edited by guerney
Thank you Bikes4two. I plan to expand the range of wheels with this kit. 700C is certain, 20" was my initial project so is in the pipeline.
The motor core is same as the standard Aikema 85SX, it has 10mm flanges. If you have quick release skewer on the rear wheel, you will need to fettle it to 10mm.
Thanks for that - might this be something to put in the installation manual (if not there already so apologies if it is)?
According to this video, the rear dropouts of the K3 Plus are 135mm wide. Similar frames may be available cheaper from some factory in China?
According to this post, the Dahon Speed Pro/TT Frame also has 135mm rear dropouts, 20" wheels, steel alloy frame, but no disc brakes.
https://www.pedelecs.co.uk/forum/threads/mini-folding-bike.10473/page-2#post-125658
Edited by guerney
Thank you Bikes4two. I plan to expand the range of wheels with this kit. 700C is certain, 20" was my initial project so is in the pipeline..................
I've been spreading the word of this kit amongst my local club mates and someone asked if you might be doing a thru-axle version as a lot of member's bikes now use these?
Thanks.
Edited by Bikes4two
I've been spreding the word of this kit amongst my local club mates and soomeone asked if you might be doing a thru-axle version as a lot of member's bikes now use these?
Thanks.
Aikema make some through axle kits but the last time I checked, the rep said that I can order preproduction kits but wasn't quite sure when mass production will start.
We will re-open on Monday 05-January.
Peaceful Christmas and a happy New Year to you and your.
  • 3 months later...
Any sign of the 700c version yet? Would it be possible to ship to Austria? I have a nice carbon Cannondale Synapse that I am thinking of electrifying as there is no such thing as a flat road around here.
Edited by chris_n
Grammar
