48v sla balance charging?
jimmyhackers
91
14
36
ok. here goes.....
i have 4x 20ah 12v sla batteries. im currently charging them on a cheap china ebay 48v charger. does the job.....just
i fear this is not charging them equally, properly or as well as they could be. max output is 56v making for 13v a cell not 14.7 : s ive also noticed the voltages between each cell being a fair way out from even
when i take them off and put them on my imaxb6 i can put in another 3-4Ah per cell.
problem is taking them all off then wiring them in parrallel to charge then unwiring them. then rewiring back onto the bike is a total hassle. takes about 15 minute to get them on charge and another 15 to put them back on the bike.
(you see why i bought the 48v charger now)
im googling but a can find a battery equilzer/balancer. i found one from hdm corpoprate systems at around 150 quid (too pricey)and that was it. anyone else had any better luck?
failing that i may buy another 3 imax b6 chargers so ill have 4 in total and charge them up that way. this still have the drawback that im not balncing batteries when discharging but oh well.
thanks in advance for the advice
jim
You can buy a good 11.5ah 48v battery with a charger for £250 from BMSBattery. It doesn't make sense to waste money on heavy SLAs
jimmyhackers
91
14
36
i have the slas already. 4x 20ah and another 4 spare 20ah when they go kaput (lucky charity shop find for 30quid) i might aswell run them into the ground, scrap them, then spend the scrap money on a lifepo4 :)
ive half solved it for now. ive bought another imax b6 charger. i can charge two batteries at a time in situe. then swap over to the next two when done.
when i eventually get a lifepo4 ill still have two of the best little battery chargers around.
Why lifepo4? Alternatives are half the weight or twice the capacity.
