I bought the above from BMS with a BBS01 kit. It all went together like a dream. I have charged the battery about 6 or 7 times now. I always plug the charger in, switch on the mains, connect to the battery (always indoors) and as usual I get a flash as the connector arcs. It is very annoying, however today the top light didn't come on and the fan didn't run :-(
I have emailed BMS however I don't hold any great hopes as they are in China.
So, has anyone had experience of the EMC-180? It is the 36V 4A, I could use a wiring diagram if anyone knows where there is one.
I am qualified in electronics (C&G 224 Power & Control) so have a scope and the usual tools, it is a lot easier if I have a diagram though.
The charger gets hot very quickly and the output is 90v when I test it with a multimeter so it looks like it's the cooling circuit/fan that has gone. I got the Kalkhoff charger out thinking that I'd see what that put out with a view to rigging something up to charge this battery and the three connectors show only one +ve connector two -ve connectors and only 5V showing on the multimeter so probably not a good idea to try and use that :-(
If anyone has any good ideas about what I can use in the mean time I'd be grateful
Thanks,
Thanks,
