Brake pads
Nevg
45
9
54
Newton-le-willows
hi,
Not long since bought the wife a 705se, but the front brake squealing is horrendous.
I'm going to try changing out to a sintered pad, and not sure which ones to buy
Nev
Nevg
45
9
54
Newton-le-willows
Bike is only a few weeks old, ive cleaned the discs and pads, but still squealing.....so I was going to try a different pad,
Apart from getting wet a few times , i can't think of anything else to try .
jdallan
306
163
A few weeks ago the front brake on my KTM started squealing and heavy braking didn't cure it. I gave the bike a good clean using Muc Off all over including brake discs and fittings. After a thorough rinse and dry the squeal had disappeared and has not returned.
Jim
Reactions: Sarabee
8,230
Try some fairy on the pads rubs them together with thumb and fore finger then rinse.
It's quite common to get squealing brakes from the salt they put on the roads in winter's but it normally goes when normal rainwater washes it back off.
Nevg
45
9
54
Newton-le-willows
Lol, my wife gives me ear ache about it
I have tried cleaning, realigning calliper. Clean and dressed pads, cleqn d rotor..
So next step is try some sinterd pads, but wasn't sure which pads I need for the cable tektro disc brakes
