Thanks, yeh I`m usually pretty good at searching out fittings myself, I have this fitting on my Aurora for the original battery and also both of my Alien conversion kits.
I could put a Kettle chassis socket in but that would prevent me from using the aurora battery that still has a fair bit of life left. I could use the worst alien conversion battery and remove the male fitting which would allow me to make a short patch lead up for use with the Li-poly and then remove it for the Aurora battery.
Shame alien have finished, they probably had some duff batteries laying around.
If i can`t find one I`ll probably have to drill a hole in the controller housing and solder in a short second lead to a separate kettle plug socket at the side.
Of course there will come a time when any of my batteries that use that fitting will be dead and a kettle plug substitute in it`s place will be the answer.
I don`t want to go to the trouble of fitting a switch so the new kettle plug patch will be live when the aurora battery is in situ but that`s not a problem.
There must be a hell of a lot of these unusual 2 pin sockets in use so it`s strange that we can`t track them down.
Thanks for looking lads.
Dave
