Could the forum width be increased?
DroidOne
52
9
69
Stockholm (Sweden)
Thanks for a great forum. I just registered an account and hope to be more active soon (...awaiting the 2017 line up).
I noticed, while browsing through all of the great content on here, that the width of the forum makes it quite hard to read.
Here's a few screenshots with the width set to 1200px. It offers a much more pleasant reading experience and less scrolling (...well, at least according to me).
Just thought I should mention it as it's quite uncommon these day with such a limited width :) (Most people are on 16:9 screens, after all).
30,376
I can't read any of those files, but the existing forum I find fine.
I'd also recommend Ctrl ++ as many times as necessary if you find difficulty.
Reactions: DroidOne
6,319
DroidOne
52
9
69
Stockholm (Sweden)
Welcome aboard. This is a 30" screen. That's 76.2cm, if you're in Stockholm. :)
You're not missing much.
I'm using a 34" UHD myself :)
just use ctrl + thats the default browser zoom ctrl - for smaller
Yes, it's possible to zoom. It does however increase the size of every single element on the page, which isn't the problem. The problem I had was specifically with the width.
I just edited the CSS via a chrome add-on; running 1400px now - looks great on UHD screens.
Since most seem perfectly fine with ~500px for the post content, I guess it's best to leave it at that.
Reactions: LeighPing
6,319
its not wide so it works on Mobil devices just use the button bottom of the page and then its the width of the screen.
Reactions: DroidOne
DroidOne
52
9
69
Stockholm (Sweden)
As SW says, use 'Toggle Width' (Two diagonal arrows) at the bottom.
Yes, that's an option for 100% width. It doesn't work very well though on WQHD+ since it overlaps the background - try it yourself. Also an easy fix though by editing the CSS and removing the background.
The best option for anyone on a higher resolution screen is probably to manually set something between 1100-1200px for better readability.
I believe that the site is responsive, so it should work perfectly fine for any mobile device no matter what the page-width is set to.
KeithMac
344
255
24
York
I use my Samsung S5 for internet, it is fine as it is (for me!).
If you make it wider I'll have to scroll left and right whitch would be a major pita..
5,785
And ergonomics? You are in design conscious Sweden you should be worried about ergonomics. Long lines of text are harder to read, scientific fact.
