I recently bought a 48v 11.6ah battery from eclipse bikes. The first time i wired things up temporarily today to test and no matter whether the power button on the side of the battery is depressed or not the blue light stays on.
surely this is not right.....?
Don't get on to Eclipse just yet. I have the same battery, and when it is connected to the controller, the blue light illuminates, whether the battery switch is on or off.
I think it does this, due to the capacitor(s) in the controller having a residual charge.
I would get the ole multimeter on the output of the battery, and test if you get 50+ volts with the battery switch on and close to zero with it switched off.
Another test, is to put the battery on the charger with the battery switch definitely off.
The blue light should be off in this state.
If you get these results, then I reckon the battery/switch is fine
