I guess I could easily copy the adaptor plate they sell in 5mm and 10mm optionsCan't you make your own adaptor out of a bit of joggled aluminium strip with two holes drilled in it?
The box didn't clear the spokes so I bought a 10mm adaptor plate and it fits fine nowHello. I'm just wondering if you found a way around the difficulty. Thinking out loud, how about fitting the magnet on an outer spoke (relative to the sensor)? It would still be close enough to the sensor and wouldn't touch the box.
It's difficult to tell from the photo, but does the box clear the spokes at least?
Thanks. I read about that but I'm not sure about what the adaptor plate. Where does it go ? I presume it creates more space between the spokes and the frame so is it like a washer you fit on the rear wheel hub?The box didn't clear the spokes so I bought a 10mm adaptor plate and it fits fine now
This is the plate - https://www.badassebikes.com/en/accessories-replacementparts/adapter-plate-10mm/a-120/Thanks. I read about that but I'm not sure about what the adaptor plate. Where does it go ? I presume it creates more space between the spokes and the frame so is it like a washer you fit on the rear wheel hub?
