I only ask as it's no longer useful to me as I'm running a 44v battery now.
Will the controller run ok if I remove it? As far as I can see it also has the wiring for the throttle, lights and brake sensors within, here's a photo of the PCB:
The Black, Green and Red wires are from the throttle and these go to the White, Blue and Green wires to the controller respectively.
The black wire to the controller appears to be for the brake lever switches, and the yellow wire is a voltage feed straight from the battery which also goes to the lights.
So, if I was to solder together the throttle cables, and also make the lights always on, then would I be able to get rid of the battery gauge and reclaim some space on my handlebars?
Or will doing this confuse the controller and stop the motor from working?
