Help Please!
Ben1972
Mar 11, 2024
Hi, my elderly father has been enjoying his second-hand Raleigh Stow-e-Way (Raleigh Evo) with a TranzX system, for a few months, but recently the motor has been dropping out momentarily at inconvenient (dangerous) times, particularly under stress.
When this happens he hears what he describes as a mechanical "graunch" noise from the back.
The battery is locked down properly, it's an intermittent fault so it doesn't show up on the diagnostic tests
He doesn't want to replace it, but cutting out as he pulls into traffic is dangerous and he's quite old. Any ideas where to go for help please?
Thank you!
2,078
Thank you!
That's mainly caused by a bad connection between the controller and motor.
The motor connector must be inserted ALL THE WAY TO THE MARKED LINE, not just in tight. Please don't come back and say that the connector is in. It's either to the line or not. That's what's important.
If that doesn't fix it, check the connector/s at the controller end.
If that's not it, check that the motor cable isn't damaged, especially where it comes out of the axle.
Ben1972
Mar 11, 2024
Thank you so much for engaging with this question, we'll look tomorrow!
8,230
Yes the graunching riders who may think it is mechnical, is actually poor electrical phase contact or phase position out of sync.
