Hi there.
Been struggling to find a wiring diagram/pinout for a controller i happened to pick up.
from a 'longwise' scooter 36v 12a... is all i can find about it... Thought i might be able to figure it out as there's only 5 pins! apart from the battery/motor. Doing my head in now though...
On the 5 pin connector all i have is battery + and - on red and black wires.... nothing on the other three... white, green, brown (with another 2 pin connector in series) ???
any ideas appreciated. Or if anyone knows of another model that uses same i might be able to find diagram for?
Update! Ok, this is what the board looks like. Powers up and i get 5v at the appropriate places? when 'VK+' is connected to VB+/battery+...
The only connections leaving the controller apart from the motor/hall sensor wires, VK+ for power up, battery + and - for voltage indicator
!!!and "TX and RX" for a control unit... no throttle or brake wires leaving box that i can see.
after seeing this thread https://endless-sphere.com/forums/viewtopic.php?f=30&t=41724&p=1194457#p1194457 with very similar silk screen markings i have tried running the throttle to 'SP' 'SP5v' and 'ground' ... this works to get 0.8-4V on SP pin... but controller is still not trying to turn motor.
Secondary switch maybe... 'BKL' maybe brake??? they have 5v on the pads at board?
Any ideas appreciated
