When i plug in my bike after a long half empting 20 mile ride i will pull out the t pin power connector from the battery make sure the charger switch is set to off, remove the rubber bung from the coax connector plug in the power then switch it on. here is where the oddness begins the first few times (more often than not the light on the charger turns orange for 3 seconds and as the fan on the charger starts the charger light turn from amber to green. Now the bike relay could do with a charge so i keep trying this and eventually it stays amber and the fan keeps going and charging occurs. Recently i have been trying to get charging to occur for as much as 10 attempts with the charger. Am i doing some thing wrong is this normal is it a battery thing
thanks as always david
