I'm looking for some advice, please, as my wife's Powacycle has now started not to charge after a good 5 years' use. I believe it has been charging only intermittently recently, but now it definitely does not work.
When I plug in the charger to the battery, the green light on the charger remains green, instead of going red, as it should, to indicate that it is charging. I have measured the voltage from the charger with a voltmeter, and it is definitely zero. However, I have also measured the voltage on the input terminals to the battery (the output is still producing a voltage, as the battery is still half full, or so), expecting a voltage (like my own lead acid battery Powabyke does), but this too has zero volts. I have taken apart both the charger box and the battery box and there is no sign of blackened terminals or boards, and the connecting cables conduct perfectly well. So should I buy a new charger or a new battery? Or should I just try to fix the battery, if it is just a blown fuse, for example.
My inclination, of course, is to buy a new charger, as it is much cheaper (though not cheap!) And I suppose I could explain the zero volts on the battery as the result of some sort of diode at the input to the LiPo battery electronics, preventing any reverse flow of current. However, I have read in several places, especially on this forum, that many people have replaced chargers only to find that it does not solve the problem of a non-charging battery.
Ideas would be most gratefully received!
Thanks,
Philip
Thanks,
Philip
