Neo Exstrem power cut out. LCD screen goes blank no power. Stop remove LCD for 30 sec. And replace it fires up and off I go for a mile or so and it happens again ! Any clues please !
After I have been out on a ride and battery had been standing for a hour or so I check it with my meter and that's the reading I get. It is a 39v battery. I just had a email from the dealer and new battery will be posted soon.Are we talking about a BH Emotion Neo Extreme? They're 36v (USA 48v). What does 24/26V mean? A 36v battery shouldn't go below 30v!
I let it cool down first for about and hour ! Just had email and I will be getting new battery,Sounds like the battery has reached its range/ limit for 24v (approx 23.2v - 29.4v) and is hitting the lvc threshold. Also batteries suffer voltage sag as they get older so could be sagging under load causing the lvc to come in to play.
Voltage reading hot off the charger ?
No such thing as a 39v battery, so if yours is a 36v then obviously its pants as you shouldn't be getting any sub 30v readings and really not much less then 32/33v at lvc.After I have been out on a ride and battery had been standing for a hour or so I check it with my meter and that's the reading I get. It is a 39v battery. I just had a email from the dealer and new battery will be posted soon.
Fingers crossed.
