I start by saying that I build batteries from scratch and can repair most non fatal issues. This one has me scratching my head. I it is a 36V 375w battery. The bike was not coming on at all so I put a power supply to it and it is fine. So I check the voltage of the battery and the voltage is fine measuring at 38.6V. I have a battery load tester so I hook it up to that and the battery immediately drops to 18V. I haven't started the load test on the tester. Just hooking it up to the tester so that the tester can read the battery causes it to drop to 18V. I tested the voltage into and out of the BMS and it has 38V going in but only 18v coming out So I changed the BMS and it is still the same. Any thoughts? Thanks all.
