active Line Plus gen 3 crank
Brian Zion
10
Hampshire
Hi all I am in the process of changing my chainring on my bosch active line plus gen 3 motor and would like advice on the torque settings for the crank arm I have put the crank arm back on its a fsa crank but not fully tighten down yet.
Gringo
1,333
835
Northampton
I couldn’t say, I just tighten as much as I can using a long Allen key, it’s done me well enough for decades ;);)
6,319
for fsa it is 29-34nm but i just do it up tight as i can ;)
6,319
you can get the bolts on there own if you want to dump the crank puller.
Reactions: Brian Zion
Brian Zion
10
Hampshire
quote from FSA Europe after I emailed them for clarity on torque 'The FSA Omega CK-200 chainset crank bolt should be tightened between 38 and 41 NM.'
