I don't know much about electronics and my wiring isn't the best but I am adding one of these volt displays to my handlebars
http://www.ebay.co.uk/itm/261242417255?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Because the wires are exposed at the back I want to make it a bit safer by adding a small inline fuse between it and the battery wire.
I have found these holders
http://www.ebay.co.uk/itm/10-AGC-5-x-20mm-5x20-Fuse-Holder-Case-In-Line-Screw-with-22AWG-Wire-Cable-DT-/171503279529?pt=LH_DefaultDomain_3&hash=item27ee645da9
The volt display spec says 20ma, will one of these 100ma fuses be ok or am I wasting my time?
http://www.ebay.co.uk/itm/10-PCS-5-X-20MM-FAST-ACTING-QUICK-BLOW-GLASS-TUBE-FUSES-100MA-TO-20-AMP-/181021643228?pt=LH_DefaultDomain_3&var=480200850857&hash=item2a25bb11dc
or is there a better solution available.
