hi Guys
I have an old Bafang BPM 48V500W Rear Driving - RPM : 328 from BMS Battery
the motor runs ok but I believe the clutch is faulty
you have to pull away very slowly otherwise the motor makes a loud screeching / clicking noise
it fine once its up to speed
I opened up the motor with the special tool took out the clutch, cleaned & checked the 3 white plastic gears (all ok)
re-greased the gears & refitted everything & it still has exactly the same fault
I can't find anyone selling the correct replacement clutch (please see attached pictures)
its the older style clutch with the 4 key slots in the central shaft
I can only find the new style clutch with the 1 key slot online to purchase
does anyone have a clutch to sell or can you tell me where to get one?
Thank you in advance
Dylan
Dylan
