Battery/Charger Compatibility
Warwick
731
225
Warwick
My Oxygen battery came with a dedicated charger and both work just fine.
I do, however, have a charger left over from when I disposed of my Woosh Sirocco and its battery. Would I be able to use the Woosh charger to charge the Oxygen battery, or are there risks involved?
awol
1,216
374
You need to check the output volts of both chargers are the same.
Reactions: Warwick
Warwick
731
225
Warwick
Thanks. Is there something in the electronic gubbins in the battery pack that stops overcharging?
8,241
Yes !!! Its called a bms.
Reactions: Warwick
Warwick
731
225
Warwick
Thank you.
Warwick
731
225
Warwick
As it happens, both chargers have the same voltage & amperage outputs. The Woosh one is smaller so that'll be the one I take on my summer tour.
