Best hub lube
WheezyRider
1,690
938
The grease used in most hub motors I've had is of poor quality and is often not applied adequately inside the hub.
The best thing I've found for lubricating hubs is Magnalube:
It makes the hub run very smoothly and it also seems to reduce noise. Has anyone found anything they think is better?
3,994
You have to be careful what type of grease you use. Mineral based greases are generally not suited for plastic gears because it gets absorbed and makes the gears increase in size over time. you should always use grease that specifically says that it's suitable for plastic gears.
WheezyRider
1,690
938
Yes it's important to be aware of chemical compatibilities. Fortunately, Nylon tends to be quite good with mineral oils:
