Hi,
I'm looking for some advice on my Pro Rider Spark ebike. I bought it as a refurbished unit about 15 months ago and it's been great but the last few trips out it's developed an issue and powers off when I'm riding. If i power it back on, it sometimes comes back showing low power then cuts out again and will do this for a few restarts then shows actual power, works fine for a few minutes then cuts out again.
The display is a Bigstone E200 (http://bigstone-nj.com/node/27) and my question is whether it is likely the display is faulty and if so where can I get a simple bolt in replacement as I cannot find this unit for sale anywhere and what should i be looking for.
rated voltage: 24V or 36V or 48v
rated work current: 10mA
switch max current output: 200mA
work mode: not communication but analog signals
There appear to be five wires:
red: battery+
blue: battery+_out(power switch)
black: battery-
white: pwm_out
green: light_out
The battery is a 36v 10.4Ah unit and is showing 42.5v after an intermittent six mile ride this morning so i believe the battery is OK. The motor is a 250w rear hub Dapu
If it's not the display, what are the other likely options? I believe the controller is in the battery casing, I've not taken it apart until i have to.
Any suggestions gratefully received as I would like to get the bike running properly again.
red: battery+
black: battery-
white: pwm_out
green: light_out
