Bottom Bearing Spindle Length
Ashley750
39
9
Kenilworth
I'm converting my bike with a rear hub kit, and whilst I'm at it I want to replace the bottom bracket, as the bearings have some play in them.
Took it out tonight, and its 68mm housing with a 116mm spindle. I am going for a Shimano BB-UN55, which comes as 68 x 115, or 68 x 118. Would it be best to go for the shorter or longer spindle? Would it even make any difference?
Thanks.
16,466
Look at the gaps between the cranks and the BB shell to see how much room is there for the pedal sensor. If there's not enough room and you don't want to modify the sensor, you'll have to get a longer one, otherwise, you can get one close to your original length. if you get one too long, the front derailleur (if you have one) might not reach as far as the big ring, so you want the BB to be as short as possible, but having enough length to install the sensor.
Ashley750
39
9
Kenilworth
With the 116mm spindle, the gap was about 9mm, so hopefully I will not need to go to 122mm or higher. My Woosh kit should be delivered today, so I'll check gaps with the existing BB and the left side pedal sensor before ordering anything new.
Ashley750
39
9
Kenilworth
Picked up a new Shimano BB-UN54 (68mm x 115mm) cassette from my bike store on Saturday only to discover:-
  • The spindle dia is 16.8mm, (old BB was 16mm) so LS sensor will not slide over it.
  • It has a plastic locking collar, that has tight slots, so the tags on the LS sensor will not slot in.
Need to pop back later to see if they have anything that will work with the LH sensor.
16,466
I can send you one if you need it.
Ashley750
39
9
Kenilworth
Thanks, I'll come back to you if my cycle store cannot help.
Do you know what thickness spacer I need to fit behind the Shimano HG-41 7 speed cassette?
16,466
5,785
If you can try and buy a BB with metal locking collar. If ever you need to remove the BB later it is much easier, the last plastic one I tried removing fell to pieces and I had a great deal of trouble removing the BB.
