Hi folks, I have a Carrera Crossfie 2018 model that has an E42 fault, which is the motor going by manual. The backwheel spins freely in forward direction but not backwards , very tough. I read somewhere that if you disconnect the 9 pin plug and it spins freely backwards the it is the mosfets in controller but that is not the case. It does not spin freely backwards whether connected or not. I belive something faulty in motor hub, Hall sensors or coils short circuit. Any ideas.
I am not too keen or experienced in dismantling motor.
What would you advise would be the best kit for this bike with existing motor which is ,
Carrera Down-Tube Ebike Battery (Pre 2019)
- 36 V
- 11.6 Ah
- 418Wh
