I've had a 2019 Carrera Vengeance Ebike for a year nearly. Bought it secondhand last summer. Ben very please with it.
Recently had a problem where the controller seemed to die and there was a short with the battery connector. Fixed that - cut off corroded battery terminals and rewired it to use two others instead. But that's when I found the controller was dead. So purchased some bits off Amazon UK to get thigs going again.
I bought the following;
Motor controller & LCD
Thumb Throttle
The stock motor on my 2019 Vengeance E is a Bafang BFSWX02 36V250W (12)
At the moment i have wired it all up - some is soldered and some connector blocks - once i have it all done properly i will likely solder all joints, heatshrinkg everything and siicon seal up - the new controller doesn't fit into the old space beneath the battery.
Initially having matched up the wires based on the colours and the wiring diagram - i could hear the motor turning but freewheeling so appeared to be running the wrong way round - one jumper type connector on the leads coming out of the controller and that was sorted.
What i'm really not sure about now is what settings to use on the controller regarding magnets or zero start. I also can't work out at present where to attach the 3 wire pas sensor - the plugs are different but it's no problem i can solder them together ok.
Found the manual referring to brown and black lines - but theres a purple cable on the controller which when connected worked and meant that once powered on the wheel spins - but it's very low power. Though it does adjust when pushing the + and - for adjusting the PAS level.
Presently as soon as I power on using the display the wheel starts turning driven by the hub motor - but there is little or no power. If i turn up the PAS on the display it has more power but it's very neutered and wouldn't be able to push the bike and a person.
After initially wiring up the battery terminal connectors, the blue/yellow/green motor phase wires and then the 6 cable for motor hall sensors i could hear the motor spinning but figured it was the wrong way.
So at the moment i have the LCD connected - the motor, but not the PAS or the throttle. Have tried hooking that up to the connectors based on the A4 maual that came with the S866 but not been able to get any further.
I have a 3 pin throttle from amazon with black/red/green wires - nothing corresponding on the leads out of the controller. Ideally i'd like to set it up with both the pas and the throttle. If possible i'd like to set it it up for more than 25.5kph - even at my weight the stock setup felt it could do more - but was limited.
The Vengeance has brake connectors with juliet cables - but not sure about wiring that up.
I have a feeling that it's all to do with the settings on the LCD for how many magnets and power settings etc but i can't work it out. I can't find a manual for the BFSWX02 and am reluctant at this stage to open it up and take a look. Though if i have to it'll be a good opportunity to do some maintenance on it.
Thanks in advance
Thumb Throttle
Thanks in advance
