Cube Cross Hybrid 400
Mike63
809
64
Hi....This bike has a 400 series battery ....what is that in ah please ?
cheers....Mike
8,788
With out looking at the specs I'm assuming 400 is the approx. battery WH which would equate to a 11ah battery @ 36v.
N.B.
Just checked the specs and is as I quoted above. Equation is simple Wh / V = Ah or Ah x V = Wh.
Mike63
809
64
Thanks Nealh....not as good as I expected on a £1600 bike.
....but it is what it is :))
many thanks......Mike
8,788
11ah should be good for approx 40 miles of mixed road /light trail riding.
Reactions: Mike63
Mike63
809
64
I understood that the rule of thumb was 11 x 3 giving 33 mile range,
weighing almost 100 kilos, I'm unlikely to get that.
....Is this no longer the case ?
....cheers.....Mike
8,788
Rule of thumb never used it for batteries as riding style/effort, weight and assist levels are unique to each rider, just my penneth worth of the range I get from my Oxydrive on a Boardman cx with my 13ah battery I have managed 60 miles and 48 miles form the 11ah. Btw I fluctuate from 82 -90 kg.
Reactions: Mike63
Mike63
809
64
Nice one, I have a 17ah battery on my Tasman 8 and I struggle to get
45 miles on a charge....always on full power though.
...so 60 miles on a 13 ah battery is good going.
.......cheers....Mike
RobF
4,732
2,312
It's only possible to give an approximate range due to so many variables.
Using tour setting on my 400 wh Bosch bikes I can get about 40 miles.
The larger 500wh would give me about 50 miles.
But throw in lots of hills, turbo setting, and a need for speed, and that range could be halved.
I've met Mike, and I reckon he would be content to bowl along on a Bosch bike on tour setting, giving the aforementioned range of about 40 miles from 400wh.
Reactions: Mike63
Mike63
809
64
Cheers Rob...I trust you're well and enjoying your biking.
..........I think you're right, I'd be quite happy with a 40 mile range or even a tad less.
There's a dealer in Bradford, some 25 miles from me, I'm gonna' try get over to look at a cube.
....cheers....Mike
