down hill forks on haibike
6,334
8,238
No good. If you have tapered head set you need tapered steerer. 650 forks are available and probably not cheap 27.5" should work. What is wrong with your current ones as they look nice? Also as I mentioned on another thread you need to consider your axle type as those ones look like a 15 or 20mm maxle no good if you have std 9mm QR type.
6,334
is there nothing to convert it then?
8,238
Yes that would work but you need the whole hope head set (top and bottom) to go with it that will fit your frames steerer tube.
6,334
have to get my bike guy to have a look as just not got the tools to do it here.
good job that i can fit them on my frame tho with the hope kit ;)
8,238
You also need to check that the steerer tube length is long enough to fit yours otherwise you will be stuck with something that's no good.
6,334
i know just the new price of them is shocking lol :) just have to find 1 second hand that will work size wise.
8,238
5.5k bike needs bargain expensive looking (1.5k) down hill forks !!!
Reactions: soundwave
gordie
15
You will need a headset reducer, Chris king or hope would be my choice.
It's a nice idea but will effect the handling quite a lot. You'll also have 2 inch more travel at the front than the rear.
DVO make some nice upside down forks with a tapered steerer but very expensive.
You also need to see if Crank Bros make a 20mm through axle conversion kit for the hubs. You will also need the 27.5" version forks if you're going with Fox 40's which are the most recent model.
