Feedback on basic main beam/horn wiring diagram requested
DarkerSide
15
Hi folks
Loving my TSDZ2 conversion, and looking to add in some additional electrics:
  • Main beam headlight (dipped headlight/DRL already provided by a dynamo-powered light), so I can retire the Exposure Strada on the handlebars
  • Horn, so I can retire the Mk1 Lungs.
I appreciate this is about as simple an ebike lighting circuit as one can get, but feedback on the attached to ensure I haven't forgotten something warmly appreciated. Key thought is: should I be activating things through relays, or can I just go direct from the switch? (PS my ability to make pretty-looking diagrams in visio far outweighs my electrical knowledge - I am an utter novice at this.)
Planned major parts: https://www.amazon.co.uk/hz/wishlist/ls/3M5T5GYG474HX?ref_=wl_share
Picture of bike for showing-off purposes...:
trevor brooker
284
158
maidstone
Hi folks
You don't need to convert to 12v - look up horn
https://www.aliexpress.com/item/32863013898.html?spm=a2g0o.productlist.0.0.50b19997zuY4ML&algo_pvid=999d0bfd-988c-47cf-b4a1-d1310ea17e0d&algo_expid=999d0bfd-988c-47cf-b4a1-d1310ea17e0d-0&btsid=0b0a187915935271079351116e3537&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
also I used these as daylight running lights
https://www.ebay.co.uk/itm/1-Pair-DC12V-85V-Universal-Motorcycle-Warning-LED-Lights-White/182577276002?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
https://www.ebay.co.uk/itm/Super-Bright-LED-Red-Fog-Tail-Turn-DRL-Head-Car-Light-Lamp-Bulb-12V-85V/333596054255?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
You can also get your main beam running off the bike battery without a convertor.
8,230
The buck converter isn't needed you can by stvzo lights with internal step down voltage and integral horn they then simply run off the battery via a switch, the the Tongsheng uses a splitter light /gear change sensor splitter cable whether this can power the lights enough I don't know.
