Fun2Ride circuit diagram needed
JOBY AKIRA
67
I have a Fun2Ride EAPC in pieces but cannot sus the wiring. Batt is fully charged the control-box is a mystery. Any assistance appreciated.
Alan Quay
2,351
1,076
Devon
At the risk of trying to get blood from a stone, can you elaborate on what's missing, and what's remaining?
At minimum you need a battery (two wires at the top), motor (three thick wires, a number of smaller ones marked hall effect) and a throttle (three small wires)
The important thing is the ignition wire, which is the thin red wire on the battery connector. It must be connected to the battery positive to work. You can bridge it to the thick red. After that, if you connect the motor power wires, motor hall wires and throttle, it should work. The rest is optional.
The three wire little black connector is for the pedal sensor. The green with the bullet is probably a battery positive for a battery level display, the two single yellows will bring in an optional function, like 15 mph speed limit, and the other two could be for high and low level brake switches. If one of them is black, as a pair, they are probably for a normal low level brake switch.
JOBY AKIRA
67
TNX guys. I will spend rest of the day experimenting. I am always confident, don't mean I always succeed, just batter attitude. Will update
Reactions: Alan Quay
