How much extra Volts can a controller take?
gullarm
10
The reason I would like to know is that I have a 36v 350W controller driving a hall effect front wheel with 2 x 8000ah 18v Lipos in series.
If I add another 18volt lipo this will give me 54 volts - surely too much?
So if I acquire a 48volt controller and another 18v lipo and then over volt to 54 would this be ok?
I just need a bit more speed I'm topping out at 15mph on the canal tow path, I could just do with nudging 20mph.
I have soldered the shunt a bit to give me a some more oomph. The speed limit wires that come out of the controller are not connected, so that cant be affecting the speed.
http://www.ebay.co.uk/itm/36V-250W-6Mosfets-E-Bike-Motor-Controller-with-LED-meter-/131305676205?pt=UK_Bikes_GL&hash=item1e926d9dad&nma=true&si=uZNjLKFhuGdN9a9b2ziWVeFUtAA%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
patpatbut
859
79
Probably not ok as most 36v controllers are using 50v capacitors.
If you use 48v controller would be fine as it uses 60v cap
Kinninvie
907
415
Teesdale,England
3 x 18.5 volt Lipos when fully charged will be at 63 volts so a 60 volt cap will blow.!
