What's the make of the brakes? Are they cable (as in a normal brake cable) activated hydraulic disk brakes?
When you buy disk brakes they should come with a plastic shim that fits between the pistons This stops the pistons closing together when doing maintenance.
If the reservoir has a certain amount of oil in it when bought then I would not go by over that amount
If it cable activated then use the barrel adjuster to put more tension on the cable, this will bring the cable attachments closer together on the caliper resulting in the brake lever not requiring so much of a squeeze .
ZOOM XTECH HB100 MTB Hydraulic Disc Calipers Front and Rear Rotor G3 160/180MM MT200 M315 160mm Rotor Hydraulic Brakes for Bikes - AliExpress 18
Smarter Shopping, Better Living! Aliexpress.com
